Introducing, new to QCAD, not 'new' to CAD
TomWS
Post by TomWS » Thu Nov 18, 2021 10:34 pm
Hello all,
just joined. I've been using various computer aided design tools for over 30 years (I'm not tellin' how many). I'm a retired EE/SoftwareEngineer and use my tools now for MY projects. My projects cover a wide range of disciplines (Woodworking, WoodTurning, Electronics (mostly Home Automation), Yard Art,...) and use a wide range of tools (Lasers, CNC Router, CNC Plasma Cutter, Wood Lathe, 3D Printer, Resin Printer, and, recently, invested in a 'mini' machine shop with a Mini Lathe & Mini Mill (not CNC))
I've used a variety of CAD programs with QCAD being the latest adventure. So far it's been one of the easiest ones to pick up and looks to be very capable as a 2D program. We'll see if it becomes my 'go to' for 2D CAD. I'll still use others for 3D & 'Arty' type stuff, although I may generate 2D Views in QCAD, we'll see...
Re: Introducing, new to QCAD, not 'new' to CAD
Post by Husky » Thu Nov 18, 2021 11:07 pm
Hello TomWS,
thanks for introducing yourself to the forum and welcome.
