Newbie
MikeP
Newbie
Post by MikeP » Fri Jul 09, 2021 1:29 am
Hi Just got into QCAD had some time with Autocad in the past so I have basics.
After long time trying I have still not figured out how to activate functions like Delete. Help!!
Re: Newbie
Post by Husky » Fri Jul 09, 2021 1:37 am
delete needs a selection to be activated. Select with the mouse what needs to be deleted, hit delete on the keyboard or below Menu / Edit / Delete - done. :wink:
MikeP
Re: Newbie
Post by MikeP » Mon Jul 12, 2021 2:55 am
Thanks thoght I had tried all options for selection, but obviously not.
another question, when I move /scroll on Y axis, the X axis moves too. and vice vesa is this normal? It drives me crazy and I keep losing image locaions.
Re: Newbie
Post by CVH » Mon Jul 12, 2021 4:25 am
In essence these are question to ask in:
- QCAD 'How Do I' Questions
- QCAD Troubleshooting and Problems
I think you mean zooming. :wink:
Shift + Wheel -or- Wheel on horizontal scroll bar = Panning horizontal.
Ctrl + Wheel -or- Wheel on vertical scroll bar = Panning vertical.
Wheel inside view panel = Zoom in/out in regard with the cursor as focus.
In the last case all depends on where you are pointing at. :wink:
Without any selection one can also pan with the arrow keys.
With the plus/minus key one can zoom in/out with the view panel center as focus.
Some behaviors can be changed under Menu .. Edit .. Application Preferences(Crtl+,) .. Graphics View .. Navigation
