Hi From the Uk
sundancermartin
Hi From the Uk
Post by sundancermartin » Thu Feb 11, 2021 10:55 pm
Hi everyone, Im looking to use Qcad for drawing 2.5d components for conversion to gcode on the mac for use on a couple of small cnc machines. cad for he mac platform is quite limited for 2d.
Im having some challenges trying to get the hatching command to work a shape created using polylines or separate shapes and trimming, hoping to get some help with that on here
Re: Hi From the Uk
Post by Husky » Thu Feb 11, 2021 11:55 pm
Hi sundancermartin,
thanks for introducing yourself and welcome to the QCAD forum.
You are welcome to ask any QCAD related question. Just post your question below the appropriate sub forum like viewforum.php?f=32 and we are happy to try to help you. Most of the time it helps if you can post the dxf or an example dxf which shows the same issue.
