New member here. Hi
fdixon
New member here. Hi
Post by fdixon » Tue Oct 06, 2020 3:45 am
Needed something that spoke dxf so I could help out my wife's brother, my "brother-in-law", with his cnc plasma cutter. He doesn't have a lot of patience with software. I use to use corel draw alot but it started to get to flacky and a change to inkscape was cause some issues. Inkscape was a ton easier to use than corel after a learning curve, but it was also causing some headaches until I found QCad and sorted them out. I really like cad for a lot of the things that need to be drawn and the pair, inkscape and Qcad, make things pretty easy.
