Hello
KMNDes
Hello
Post by KMNDes » Sat Sep 19, 2020 10:18 pm
Kevin McNeill, small boat designer, been using QCAD for several years now and just updated to 3.25.5. Was happy but very unhappy now.
Re: Hello
Post by Husky » Sat Sep 19, 2020 11:23 pm
Welcome to the QCAD forum.
3.25.5 isn't an official QCAD update. The current version is 3.25.2
Please elaborate why. Thanks.
KMNDes
Re: Hello
Post by KMNDes » Sun Sep 20, 2020 12:04 am
Meant .2, slip of the lip. Unhappy because the screen resolution is bizarre, looks like it was designed for the nearly blind. Plus I can't get back to my previous version.
Re: Hello
Post by Husky » Sun Sep 20, 2020 12:33 am
Honestly - I've no idea what do you mean. Howsoever - I assume it is fixable ... :wink:
Please post a new topic regarding your problem below "QCAD Troubleshooting and Problems".
https://www.qcad.org/rsforum/viewforum.php?f=33
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- in this case (!) Indicate the exact version of QCAD you used before the update
- Indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition)
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
- If using a command line tool, indicate that exact command used
Re: Hello
Post by andrew » Mon Sep 21, 2020 9:21 am
You can always go back to a previous version. Simply install the older version again if you are installing from an MSI file.
