Hi from PA
pawonfire
Hi from PA
Post by pawonfire » Fri Jun 05, 2020 4:38 pm
Hi, Phill from Pennsylvania, USA here. I'm a controls engineer using AutoCAD then Draftsight for electrical schematics and electrical panel layouts. I couldn't justify the annual subscriptions, because most of my work is in programming.
Tried QCAD and a few other options last year, QCAD worked so well I purchased it. Have been using it for the last year with only minor issues printing older files, all taken care of. Forum support has been awesome, thanks for your hard work!
Re: Hi from PA
Post by andrew » Fri Jun 05, 2020 10:34 pm
Thank you for your introduction and feedback and welcome to the forum!
