Hi From the United Kingdom :)
ExWhyZee
Post by ExWhyZee » Sat Sep 15, 2018 12:26 am
Just Thought i would say Hi From the U.K
Having Tried various 2D CAD Programs - I found QCAD to be the easiest 2D CAD to learn & Get Jobs Done Quickly. I Did not hesitate to buy it after trying the free version.
I use another Program for 3D CAD but for 2D QCAD does everything i have needed so far but i am sure there is much more i can learn hence i joined this forum :)
Best Regards from ExWhyZee ( U.K ) :D
Re: Hi From the United Kingdom :)
Post by Husky » Sat Sep 15, 2018 1:26 am
Hi ExWhyZee - welcome to the QCAD Forum.
... but i am sure there is much more i can learn hence i joined this forum :)
Yep - the nice thing in a forum is that we can learn from each other and grow together. :wink:
Best regards from the US :D
Moderator / Drawing Help
Post by Clive » Sat Sep 15, 2018 8:01 pm
Yes welcome ExWhyZee from another UK user.
