Page 2 of 2
Re: Imperial (US) drawing sheet templates, ANSI A-E
Posted: Tue Jan 25, 2022 7:56 am
by Husky
rluke wrote: ↑Tue Jan 25, 2022 2:25 am
These templates are great.
I'm glad to hear they are helpful to you!
Question: When I open them they show up in "model space". Is that where they belong or should they be cut and pasted into the layout (paper space)?
Or should they be imported instead of opened?.
Yes - they are made for model space. Imported or opened? Depends on your workflow.
Layout? Now we are talking ...
If you work with QCAD on a semi professional base I would recommend to use them as a source to create a proper template. Those templates could content every basic what you need for new drawings like layouts, layer, blocks etc.. QCAD will duplicate those templates for new drawings (CTRL+N) - the original stays untouched ...
In my case I created a template for all my basic layer and blocks, a paper space for landscape and one for portrait prints. When I start a new drawing I have already my "personal" default setup and just delete at the end of the job what I haven't used. Yes, I'm lazy ...
My default setup for new drawing:
- Husky-2022.01.24-02.png (44.6 KiB) Viewed 39663 times
Posted: Tue Jan 25, 2022 10:02 pm
by rluke
Husky.. thanks for the reply.
Sorry for all the questions.. I don't want to start off going down the wrong path. I want to create a template for sure.
I've been accustomed to having the title block and such on the drawing sheets (or paper space as they are called here). Would copying that stuff onto the paper space cause any type of issue?
Rich
Posted: Tue Jan 25, 2022 10:58 pm
by Husky
rluke wrote: ↑Tue Jan 25, 2022 10:02 pm
No.
If you use my drawings as base unlock in Model_Space the layer "9.1 Drawing sheet". Then select everything, copy with reference (0,0) into the clipboard, open a Paper_Space, paste the clipboard content to 0,0. Rename the Paper_Space regarding to the content.
Keep in mind that the easiest way to deal with different scales in Paper_Space would be to keep Border, Paper Frame, Title block etc etc in 1:1. A print out of Paper_Space is then also done in 1:1. If you need to scale something, even different scales, that is handled within the scale used in a Viewport.
https://qcad.org/en/tutorial-working-wi ... -viewports
Posted: Wed Jan 26, 2022 2:13 am
by rluke
Ok
Starting to make sense now. thanks... thanks
Rich
Posted: Fri Jan 28, 2022 4:06 pm
by rluke
I've been trying to build a template with various size layouts (paper space). All is well when I load the first of these nice templates. It does not matter which on I load first. But when I import another I am running into some trouble. The paper frames don't match anything. They are either out of scale or not correct. All my scale factors are set to 1:1. I know I'm missing something just not sure what?
Rich
Posted: Fri Jan 28, 2022 8:04 pm
by Husky
Hi Rich,
rluke wrote: ↑Fri Jan 28, 2022 4:06 pm
Looks already good!
Here is what happens: You are importing or copy/paste different sizes of frames. ANSI A, B, C. Those sources are as far as possible standardize what means they are built under the same rules and use the same names for the same things (who did that???). That is in this case the issue but easy to "fix"!
If you import or copy/paste a block with the same name in the target drawing you have the option to overwrite the same name block or not. Overwrite means the block from the source will be used - not overwrite means the block in the target will be used. However - in this case both methods would be wrong.
To avoid this you have to rename one of the identical block names. Target or source block - doesn't matters.
In short: Rename in the source drawing for ANSI C the blocks to "Paper Frame C" and "Zoned border C" and copy/paste them into the drawing "template test ABC.dxf". You have to do that for all source drawings ...
Posted: Fri Jan 28, 2022 10:08 pm
by rluke
That worked great ! Thanks so much... I never would have figured that out.
Rich
Posted: Fri Jan 28, 2022 11:21 pm
by rluke
It looks like I should also rename the "Title" and "Revision" blocks the same way as the Paper Frames. Am I correct ?
Rich
Posted: Mon Jan 31, 2022 7:17 pm
by Husky
rluke wrote: ↑Fri Jan 28, 2022 11:21 pm
Depends on what you're doing but I don't think so ...
Posted: Tue Feb 01, 2022 1:33 am
by rluke
Thanks again for making those templates... ... really great
Posted: Wed Feb 09, 2022 4:20 am
by rluke
I've filled in some of the attributes on the title block. That's a nice feature.
Question: When I toggle the visibility of the title block to [OFF} the attribute text remains visible on the layout. Can the attribute text be hidden?
thanks
Rich
Windows 10 home
QCad pro trial
Posted: Wed Feb 09, 2022 10:02 am
by Husky
rluke wrote: ↑Wed Feb 09, 2022 4:20 am
Yes. As you know everything in CAD lives on layer. Put the Attributes on a designated layer and switch the layer to invisible.
Posted: Wed Feb 09, 2022 10:09 am
Block attributes are separate entities, not technically part of the block.
You can use this application preference to hide block attributes when the block is hidden:
Edit > Application Preferences > Graphics View > Behaviour > Hide attributes when block references are hidden
Posted: Wed Feb 09, 2022 2:12 pm
by rluke
That worked perfect ... thanks thanks
Rich
