Hi Guys
Recently I have been designing some 'Laser Cut' radiator cover screens. Please see attached a dxf file with which you will find a block of the original design and a block of the grid layout which you can use to design your own cover screen design with QCAD .
The grid can be used to design cover screens up to 900mm x 610mm (with a margin of approximately 20mm). Your own design of shape/s works best if they fit an individual size of 21mm x 20mm.
Simply copy and paste your shapes to the grid intersections.
Radiator 'Cover' screen - laser cutting/layout grid
- Radiator panel cover screen - layout grid.dxf
- (172.15 KiB) Downloaded 1083 times
- Radiator panel cover screen smaller.png (126.45 KiB) Viewed 23919 times
- layout grid smaller.png (54.89 KiB) Viewed 23919 times
