Hi guys
Anyone into 'bugs' (not program bugs we have a bug tracker for that!).
If you`re anything like my son you will love bugs
I have attached a laser cutting file for some bug houses, you can resize as you need - very useful for schools or 'the back garden'
laser cut 'Bug Houses' file
- laser cut- bug houses.dxf
- (5.51 MiB) Downloaded 1175 times
- laser cut - Bug Houses.png (37.21 KiB) Viewed 31211 times
Re: laser cut 'Bug Houses' file
Here is a photo of the laser-cut 'Bug Houses' - designed with QCAD 3.
Line weight ideally should be 0.00mm when sending to the laser cutter!
- bug houses.png (259 KiB) Viewed 30962 times
Hi Clive,
thanks for the Photo. Now I can imagine how it has to look like. Nice Project!
