Progrm "Help" access after switch from Demo to Pro
Locked
rbloth
Post by rbloth » Mon Jun 15, 2009 5:00 pm
I switched from the Demo version to the Pro version (2.2.2.0) and uninstalled the Demo. Now when I access "Help -> Manual" and click on any item in the Index tab, I get this message:
The page could not be found
'file:///C:/Program Files/QCAD Professional Demo/doc/chapter19.html#3 points circle'
I have searched the Windows registry as well as the installation directory for clues but haven't figured out how to fix the problem (other than recreating the "QCAD Professional Demo/doc" directory and copying the help files into it).
Using QCAD under Windows XP Pro.
Thanks!
- RBL
Post by andrew » Tue Jun 16, 2009 7:10 pm
Locked
Return to “QCAD 2.1/2.2 Troubleshooting and Problems”
