Permissions
30tooo
Permissions
Post by 30tooo » Wed Nov 23, 2011 12:12 pm
I am having trouble saving files . If I load a file , modify it , and then try and "save as" , i get an error message . it says "Cannot save the file ,file title,Please check permissions". This also happens when I try and save a new file .
I have not found out how to check permissions in Qcad . If I get info on the file and unlock everything I still can't save . I have repaired permissions using the Disc Utillity as well as reinstalling QCAD . Still no joy .
Does anyone have any ideas please .
I am running a G5 iMac PPC with Mac OS 10.5.8[/img]
Post by andrew » Wed Nov 23, 2011 12:55 pm
Please indicate your exact version of QCAD in every post.
Please post information about where (what directory) you are trying to save the file as well as the file name, thanks.
