Visibility of block
Locked
VOK
Visibility of block
Post by VOK » Sun Jul 03, 2011 11:40 am
I am unable to successfully change the visibility of a block that contains text. I have toggled the visibility to off, however the program is still able to select an intersection point of the components of the text even though they cannot be seen. I have tried setting the text to a separate layer, and disabled this layer, this was also unsuccessful
I am using QCad 2.2.2.0 on Windows 7 64
Locked
Return to “QCAD 2.1/2.2 Troubleshooting and Problems”
