Minimum file size for saving
bluequad
Post by bluequad » Thu May 19, 2011 1:00 pm
Operating system Windows Vista Home Premium. QCAD version 2.2.2.1
Does QCAD only save files above a certain size? I have created a simple logo, because the latest version 2.2.2.1 no longer supports jpeg images. When I try to save it, the saved file is empty.
Am I doing something wrong?
Re: Minimum file size for saving
Post by andrew » Tue May 24, 2011 10:18 am
bluequad wrote:Does QCAD only save files above a certain size?
No. QCAD saves any drawing (also empty ones or drawings with only a few elements).
Something else is wrong, could be a number of things. Could you send your seemingly empty DXF file to: info [at] ribbonsoft [dot] com?
