JPEG images disappeared and not importing
bluequad
Post by bluequad » Tue May 10, 2011 4:45 pm
I have previously created and saved a series of drawing sheets with an imported logo. The logos have disappeared from all the templates and I cannot now import the original JPEG image.
Some time ago I upgraded to the most recent software to avoid crashes when opening files. Is this the problem or is there some other selection that I have overlooked?
Post by andrew » Wed Jun 29, 2011 8:26 am
QCAD 2.2.2.1 does not support the JPEG image format due to an update of underlying libraries. I suggest to use the PNG format instead.
QCAD 3 will support JPEG, PNG, BMP and other formats again.
