QCAD Prof V2.2.2.0, WindowsXP. Library Browser insert proble
Posted: Sun Mar 07, 2010 7:05 pm
- I use QCAD Professional V2.2.2.0 on Windows XP Professional SP3.
- I want to report the following problem...
- When inserting a block (drawing) using the Library Browser, the layer
properties (Color, Width, Line type) of the inserted block are temporarily
override by the layer properties of the layer in which the block is inserted.
To get the inserted block layer properties restored, I have to do a dummy
"Modify->Properties" on the inserted block, or close and open the drawing.
Claude Sylvain
Electro-Technica inc.
Claude Sylvain
