[Solved] JPEG Layer when enabled make other layer disappear
mmartins
Post by mmartins » Mon Jan 31, 2022 8:35 pm
I am running in my MAC Catalina 10.15.7 and 3.27.1 QCAD. All layers work fine except when I enable a layer with a JPEG drawing to be used as a background. When the JPEG layer is visible the other layers will only become visible while I hover my mouse over them.
Is there a way to make the JPEG layer to be allways on the background? The JPEG layer is a Google map that I use as reference for the other layers over it.
Thank you
Re: JPEG Layer when enabled make other layer disappear
Post by andrew » Mon Jan 31, 2022 9:18 pm
Layers are not related to draw order in CAD.
You can select the bitmap and choose Modify > Draw Order > Send to Back.
You also might want to lock that layer, so the bitmap is not getting in the way of your drawing.
mmartins
Post by mmartins » Wed Feb 02, 2022 7:12 pm
Hi Andrew, I followed your suggestion, but it still not working. I have only this layer selected which is a JPEG file, I am able to click on it and select modify and send to back, when I make another layer visible I can see the other layer on top of the JPEG layer and as soon I move the cursor over the cad drawing the only layer I see is the JPEG, however when the cursor hovers the other layers it will show correctly as long as the cursor is positioned over that specific layer.
Post by Husky » Wed Feb 02, 2022 8:01 pm
Did you lock the layer as mentioned from Andrew? Additional you might also fade the image within the Property Editor - maybe 60 or so ...
mmartins
Post by mmartins » Thu Feb 03, 2022 2:50 am
Hi Husky - I locked all layers and now it works as I wanted. Thank you for pointing it out. I was under the impression locking the layers was optional apparently not. Can I lock only that one layer instead locking all layer? Sorry if I ask a simple question. Thank you
Post by Husky » Thu Feb 03, 2022 3:06 am
If you lock all layer then you can't work on the drawing anymore. Just lock the layer which contains the jpg's (and only jpg's!) and it works like a charm ... :wink:
mmartins
Post by mmartins » Thu Feb 03, 2022 3:11 am
Perfect! Thank you for replying to my basic questions.
