I'm sorry, I have no idea.John Hyslop wrote: ↑Sun Mar 08, 2020 2:33 am... somehow it seems to of reversed some arcs? any idea what might be going on...
Open Source Nesting
Re: Open Source Nesting
Pls, attach your files.
That would not be the first issue with SVG.
- Premier Member
Hi Husky
I did attach the svg file? did you want the dxf too?
See attached...
Cheers
John
See attached...
Cheers
John
- Shape-01 - Rev B.dxf
- (374.58 KiB) Downloaded 1350 times
Rather all arcs look to be reversed in your screengrab.
The dxf and the re-imported svg consist both out of 53 non-reversed arcs.
Setting something else as 'White' and 'Default' for the lines:
Looks ok in a browser.
Opens ok in Inkscape.
So it is a Deepnest issue.
Did you try reversing the arcs, or conbined to a polyline?
Hi John,
Nope - I haven't ask for the dxfJohn Hyslop wrote: ↑Sun Mar 08, 2020 9:40 amHi Husky
- Premier Member
Hi Both
I reckon it's the nesting program too..
I also opened up svg in inkscape but only displayed rectangle but AutoCAD opened the dxf with no problems..
CVH yes same issue with polylines...
Silly me rectangle was white on white saved from inkscape as DXF and all arcs are ok..
Cheers
John
Cheers
John
- Premier Member
Hi Husky
Deepnest cannot process SVG files correctly every one I've tried so far fails all arcs are reversed..the pc I'm using is offline..I bet it will work while online..pity it looked very promising..
Cheers
John
Cheers
John
You lost! Online / offline does not matter. SVG fails in both scenarios. Good to know ...John Hyslop wrote: ↑Mon Mar 09, 2020 11:51 amI bet it will work while online..pity it looked very promising..
- Premier Member
Damn...there is always qcad/cam at a small investment
- Premier Member
Hi Husky
I made this for you... it will save you a fortune on internet cables LOL
Works in Windows up to 10, not sure about Linux....
Cheers
John
PS If you don't want it delete this post
Cheers
John
- Net-On-Off.zip
- (217.86 KiB) Downloaded 1333 times
- Network On & Off.jpg (7.18 KiB) Viewed 44649 times
Deepnest is what they call 'abandonware'.
Jack Qiao (Jack000) never did surface again after 2018.
https://github.com/Jack000
http://jack.works/
There is a fork with later commits:
https://github.com/InfernoEmbedded/Deepnest
Deepnest is based on SVGnest from the same author.
Last commit there is from april 2019.
Deepnest and SVGnest topics are spread over many sites and pages.
I did came across some demands and commits about arcs but not as we are experiencing.
Found a mail address: jak000 at gmail.com
(had to chop that address or the msg failed as spam)
Many are trying to reach him.
Pitty, it looked promising.
http://jack.works/
- Premier Member
Hi CVH
Interesting.. thanks
Cheers
John
Cheers
John
Does anyone know if either of these free nesting software programs will nest rectangular parts within a random shape. I want to cut leather belting/strips from a full cowhide and plan to trace a profile from a scaled photograph. This is sort of reversed from the usual but any program that will nest parts within parts could possibly do this.
I'm using an older liscenced version of Autocad (on a 64 bit system) to create the outline and should be able to convert to DXF or SVG possibly. I'm assuming these are standalone programs and not an addon to QCAD.
EDIT: I had not read to the last few posts about both of these being abandoned is there anything else that's freeware or open source?
I just noticed that not many people are working on any improvement on a wheel. Means that wheels are all abandoned? ...
Just try it yourself - it doesn't hurts and it doesn't cost money.
Abandoned? I think it isn't on us to make a statement like that! There could be a bunch of reason why it looks abandoned - that doesn't means it is abandoned!
