Tip - how to move the main CAD Tool bar
Clive
Moderator
Post by Clive » Thu Feb 28, 2013 10:58 am
Hi Guys
You will most likely know that menus and toolbars can be moved/dragged and docked into new positions in QCAD.
However, at first it may not seem apparent that you can do the same with the 'main' CAD tools, here is a little tip to enlighten you.
1. Here we see the main CAD toolbar.
Cad Tools 1.png (7.11 KiB) Viewed 9006 times
2. If we now 'right-click' in the toolbar space we are presented with an option to toggle the Title Bar.
Cad Tools 2.png (13.41 KiB) Viewed 9006 times
3. Click on this and... this now allows us to drag and move the tool bar into a new position, here you see I have docked the toolbar above my drawing area (Model space).
Cad Tools 3.png (16.77 KiB) Viewed 9006 times
4. To make more space and remove the title text - simply 'right-click' again.
Cad Tools 4.png (11.86 KiB) Viewed 9006 times
5. Click on this and... this will remove the title and leave only the CAD toolbar, now you can move up your main drawing area to suit! :wink:
Cad Tools 5.png (11.28 KiB) Viewed 9006 times
