How Do I change color on a block
Chrisp
Post by Chrisp » Sat Sep 06, 2008 9:50 am
My problem is, that I use the same block in the same layer. The blocks are laying in different angels. To distingish I would like to give a different color to each block. How to I do that?
THX
Chris
Post by andrew » Sat Sep 06, 2008 10:52 am
1. Edit the block.
2. Change the color of all entities that are part of the block to "ByBlock".
3. Close the block editing window.
4. Change the color of the individual block inserts to the desired colors.
