Offset
Locked
roguepoint
Offset
Post by roguepoint » Wed Jun 25, 2008 12:51 am
I am sure this has been covered many times but I am new to Qcad, in from R14, Where is the offset command, and is there a print friendly manual?
Re: Offset
Post by andrew » Wed Jun 25, 2008 10:16 am
roguepoint wrote:I am sure this has been covered many times but I am new to Qcad, in from R14, Where is the offset command,
Try the command 'offset' or Draw - Line - Parallel
roguepoint wrote: and is there a print friendly manual?
http://www.ribbonsoft.com/qcad_doc.html
Locked
