Move points along with scaled image
mmasroorali
Post by mmasroorali » Wed Mar 07, 2012 2:19 pm
Dear All,
Let us say that I have put two points on an imported image inside qcad. Then, I scale the image by some factor. If I use either of the points as the reference point, its position in the image remains unchanged. But the other point moves way off its original position on the image.
How can I automatically move both the points along with the image when it is scaled? As a result, the relative position of the points with respect to the image will remain the same.
Thanks in advance.
Post by andrew » Wed Mar 07, 2012 2:27 pm
If you select the image and both point and scale them all at once with any reference point, the position of the points relative to the image should of course stay the same.
mmasroorali
Post by mmasroorali » Wed Mar 07, 2012 2:39 pm
Thanks, it was so easy.
