Copy from Command Line History
rdf13
Post by rdf13 » Sun Jan 02, 2011 4:10 am
Although I am able to select text from command line history, copy (both <cntl> C and the copy command from the menu) does not appear to work. The reason I would like to copy information from history is that polygon area is displayed there and I would like to be able to paste to my spreadsheet.
Post by andrew » Mon Jan 03, 2011 9:35 am
Try to select the text to copy, right-click on it and choose "Copy" from the context menu.
If you're under Mac OS X and have a one button mouse, try holding down the Control key while clicking the selected text to show the context menu.
