[solved] QCAD Versions
johng
Post by johng » Mon Oct 17, 2022 7:59 am
I have just bought and will be installing QCAD. I have tried it once in the Trial Version but you don't really get a chance to use it properly there, so to QCAD I'm a complete Newby. I have however successsfully used LibreCAD and decided on QCAD due to the Text Limitations there. My requirements are largely electrical and single line drawings so 2D is good for my needs. I could not find an elctrical forum so will use the others and perhaps the Deutch too.
Question: I downloaded two versions QCAD qcad-3.26.4.13-pro-win64-installer.msi; qcad-3.27.8-pro-win64-installer.msi
What is the difference? As a Newby which should I use?
Thanks in advance
Re: QCAD Versions
Post by Husky » Mon Oct 17, 2022 8:09 am
Hi johng - welcome to the QCAD forum.
It is recommended to use always the latest QCAD Pro release. In this case the 3.27.8.
The differences can be found in the changelog below:
https://www.qcad.org/en/changelog
johng
Re: QCAD Versions
Post by johng » Mon Oct 17, 2022 8:39 am
Thanks, so from the Change Log, it looks like no concept of "Stable Version" in QCAD developement :idea:
Re: [solved] QCAD Versions
Post by CVH » Mon Oct 17, 2022 8:59 am
"Stable Version" means running stable on all platforms.
That doesn't mean bug-free. :wink:
johng
Post by johng » Mon Oct 17, 2022 10:34 am
Could that mean that V 3.26.4.13 is likely to be more "bug free" than the current version?
Post by andrew » Mon Oct 17, 2022 10:39 am
3.26.4.13 was downloaded from the "Snapshots" folder of your download page. Please read the "Information about Snapshots", also on your download page:
Snapshots
Snapshots are packages with the current development version of QCAD. Snapshots should be considered unstable and are not intended for production use.
The current stable release is 3.27.8, that's the one you should use.
johng
Post by johng » Mon Oct 17, 2022 12:52 pm
Thanks one and all!!!
