[solved] Installation on Kubuntu 22.04
Pierre de Québec
Post by Pierre de Québec » Fri Oct 14, 2022 1:01 pm
When starting version 3.27.8, I get the following message:
/home/maison/opt/qcad-3.27.8-pro-linux-x86_64/qcad : ligne 13 : 7271 Erreur de segmentation (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=0 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
This message appears both with the installation made with QCAD Professional 3.27.8 for Linux 64bit (Installer) and with QCAD Professional 3.27.8 for Linux 64bit (tar.gz). For the moment, I have put version 3.27.7 back into use.
Operating System: Kubuntu 22.04
KDE Plasma Version: 5.24.6
KDE Frameworks Version: 5.98.0
Qt Version: 5.15.3
Kernel Version: 5.15.0-50-generic (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-7400 CPU @ 3.00GHz
Memory: 15.6 Gio of RAM
Graphics Processor: NVIDIA GeForce GTX 1660/PCIe/SSE2
Thank you for the help you will give me.
Pierre
Re: Installation on Kubuntu 22.04
Post by andrew » Fri Oct 14, 2022 1:04 pm
Please try the package "QCAD Professional 3.27.8 for Linux Qt 5.14 64bit (Installer)" instead for this platform.
Pierre de Québec
Post by Pierre de Québec » Fri Oct 14, 2022 3:20 pm
Thank you, It works!
Pierre
