Below is a quick fix to the qcad script (linux, maybe mac also), so that it will work if the qcad command is symlinked to (say) /usr/local/bin or some such location. The short story is to fix as follows:
#OLD
#DIR=${BASH_SOURCE%/*}
#echo DIR=$DIR
#NEW:
FILE=$(readlink -f ${BASH_SOURCE})
DIR=${FILE%/*}
#DEBUG: echo FILE=$FILE DIR=$DIR
Version: qcad-3.27.1
OS: linux ubuntu-21.04, but should apply to any linux
The long story:
Installed from .tar file:
cd /usr/local
tar -ztvf /local/loc1/rpm/qcad-3.27.1-trial-linux-x86_64.tar.gz
tar -zxvf /local/loc1/rpm/qcad-3.27.1-trial-linux-x86_64.tar.gz
/usr/local/qcad-3.27.1-trial-linux-x86_64/qcad WORKS
# Try to link qcad into /usr/local/bin
# the below symlinks do not work
% ln -s /usr/local/qcad-3.27.1-trial-linux-x86_64/qcad /usr/local/bin
% qcad
/usr/local/bin/qcad: line 11: /usr/local/bin/qcad-bin: No such file or directory
# does not help:
ln -s /usr/local/qcad-3.27.1-trial-linux-x86_64/qcad-bin /usr/local/bin
Fatal: This application failed to start because it could not find or load the Qt platform plugin "xcb"
Also tried using hardlink, that does not work either. Try to fix in the qcad script:
#OLD
#echo DIR=$DIR
#NEW:
DIR=${FILE%/*}
With these changes, the symlink
will run properly.
Fix for qcad linux script so that qcad command can be symlinked
Re: Fix for qcad linux script so that qcad command can be symlinked
What I've done on Xubuntu 18.04 is to install from a Deb package, which installs to /opt/qcad<version>. I symlinked /opt/<qcad>version to just /opt/qcad, which is where my desktop files point. So when I upgrade, I just remove the existing symlink and re-link the new directory. Having version-specific install directories allows simultaneous installation of multiple versions, but it does add a little complexity to in-place upgrades.
I never start QCAD from a command line, but I appended /opt/qcad to my path for the command line utilities that ship with QCAD, should I ever need them. For me, the ./qcad symlink is a reasonable compromise but your needs may be different.
Len
QCAD Pro
QCAD Pro
