Instalation of QCAD Professional
AJSR
Post by AJSR » Mon Nov 22, 2021 10:20 pm
Today I bought QCAD Professional
Into the link I received in the e-mail, I downloaded the QCAD Professional Windows 64bit file (Installer) for Windows 10, 64 bits and then I ran the received file qcad-3.26.4-pro-win64-installer.msi, running the installation process.
To launch QCAD, doubleclick the QCAD icon on the desktop, which installs the QCAD Professional Trial application.
qcad.exe is from 2021-06-04 09:19 with 159 608 bytes.
As the installation procedure does not mention this situation, I would like to get support to perform a correct installation.
Thank you very much,
Re: Instalation of QCAD Professional
Post by andrew » Mon Nov 22, 2021 10:25 pm
Running the Full Version of QCAD Professional
Please make sure that after downloading the full version, you also install the full version (not a previously downloaded trial version that still happens to be in your download folder).
Please make sure that after installing the full version, you also run the full version (not a previously downloaded and installed trial version).
If in doubt, uninstall all versions of QCAD and install the full version from scratch.
The trial version cannot be turned into a full version or the other way around.
AJSR
Post by AJSR » Mon Nov 22, 2021 11:15 pm
I uninstalled the installation I ran for the full version.
I deleted all QCAD files and folders from disk.
I deleted a registry entry for qcad.exe
I re-downloaded the installation file and verified that it had the same size as the previous one and the same number of files.
I ran the installation and now I have the full version properly installed.
Thank you very much.
