[solved] Multiple QCAD versions on one machine macOS
toob
Post by toob » Mon Nov 08, 2021 12:20 pm
How do I install multiple versions of QCAD on single machine?
- macOS 11.6
Re: Multiple QCAD versions on one machine
Post by andrew » Mon Nov 08, 2021 1:05 pm
On macOS, each application is bundled into a single directory (an "application bundle"). This is what appears as application icon which you would typically double-click to launch. You can have multiple of these application bundles for different versions of QCAD. Simply rename them with the version in the name (e.g. "QCAD-Pro-3.26.4").
toob
Post by toob » Tue Nov 09, 2021 4:53 am
Thanks, I'm marking this topic as solved.
