user config file migration (solved)
bambuko
Senior Member
Post by bambuko » Mon Oct 18, 2021 8:11 am
I am re-installing QCAD in a PC with new distro.
Is it possible to copy and paste user config file from existing setup?
or is it a case of laboriously setting up preferences again?
QCad Pro
Linux MX-21.3 "Wildflower"
Re: user config file migration
Post by andrew » Mon Oct 18, 2021 9:12 am
Yes, you can copy the file QCAD3.ini over.
Please refer to our web site to find out how / where you can find this file:
https://qcad.org/tutorial-resetting-the ... on#Windows
bambuko
Senior Member
Re: user config file migration (solved)
Post by bambuko » Mon Oct 18, 2021 12:27 pm
Thank you @andrew
and sorry for asking - the answer was hiding in a rather not obvious (at least to me) place :mrgreen:
and for those who do not speak German, the link is:
P.S. perhaps tutorial should make it clear as well, that it is not only "...to reset QCAD to its default configuration..." e_confused
QCad Pro
ryancousins
Post by ryancousins » Mon Oct 18, 2021 2:51 pm
I agree that broadening the description of resetting the config to also include transferring it might be helpful. The first time I wanted to do that I didn't think to look at the reset config tutorial under "Troubleshooting".
