problem installing Pro version on new Linux Laptop [Solved]
Ironfighter
Post by Ironfighter » Sat Jun 26, 2021 7:10 am
I am trying to install on a new laptop but have run into a problem.
I download the 64 bit "run" file, transferred it to my /opt folder, made it executable, double clicked it and nothing happened. after numerous attempts I downloaded the Tar file, moved it to the opt folder, made the qcad file executable (and the qcad-bin file). Double clicked and nothing happened. I went on the MX forum seeking advice thinking it was an operating system issue (which for all I know it may be).
I was told to run the command ./qcad from a terminal opened in the qcad folder -/opt/qcad-3.26.4-pro-linux-x86_64/
Programme opened up instantly but will not open if I double click the file.
No desktop icon though so does this mean it hasn't been installed. Nothing in the MX menu either.
Any help and advice would greatly appreciated.
[code]
System:    Host: <filter> Kernel: 5.10.0-5mx-amd64 x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-5mx-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-19.4_ahs_x64 patito feo March 31  2021 base: Debian GNU/Linux 10 (buster)
Machine:   Type: Laptop System: LENOVO product: 20NFA00PAU v: ThinkPad E595 serial: <filter>
           Chassis: type: 10 serial: <filter>
           Mobo: LENOVO model: 20NFA00PAU serial: <filter> UEFI: LENOVO v: R11ET40W (1.20 )
           date: 11/17/2020
Battery:   ID-1: BAT0 charge: 43.8 Wh condition: 43.8/45.7 Wh (96%) volts: 12.4/11.1
           model: Celxpert 5B10W138 type: Li-poly serial: <filter> status: Full cycles: 1
           Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M187 serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
           type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24) stepping: 1
           microcode: 8108102 L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36728
           Speed: 1827 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 1147
           2: 1140 3: 1690 4: 1695 5: 1395 6: 1445 7: 2241 8: 1361
           Vulnerabilities: Type: itlb_multihit status: Not affected
           Type: l1tf status: Not affected
           Type: mds status: Not affected
           Type: meltdown status: Not affected
           Type: spec_store_bypass
           mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2
           mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
           Type: srbds status: Not affected
           Type: tsx_async_abort status: Not affected
Graphics:  Device-1: AMD Picasso vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel
           bus ID: 05:00.0 chip ID: 1002:15d8
           Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati
           unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
           OpenGL:
           renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0 5.10.0-5mx-amd64 LLVM 11.0.1)
           v: 4.6 Mesa 20.3.4 direct render: Yes
[/code]
Re: problem installing Pro version on new Linux Laptop
Post by andrew » Sat Jun 26, 2021 10:00 am
You'll have to run the downloaded installer (not attempt to open it).
For detailed installation instructions for Linux, please refer to:
https://www.qcad.org/en/component/conte ... tion-linux
Ironfighter
Post by Ironfighter » Sat Jun 26, 2021 11:52 am
Thanks for your response Andrew. I did try to follow the instructions in your link when I first downloaded the “installer” file - as I said I made numerous attempt before I reverted to downloading and extracting the Tar file.
It seems I have gone wrong somewhere towards the end of the proceedings because I never got to the “do you want to run” pop up.
I think the best thing for me to do is delete all the existing files in my opt and download folders and start again by downloading the installer again and following the instructions.
I won’t be able to do this till Monday AEST but will post an update.
Just one question before I do that. In this installation of MX Linux it seems the opt folder is owned by root. Could that have something to do with my difficulties?
Post by andrew » Sat Jun 26, 2021 2:18 pm
QCAD installs into the opt folder of the user who installs it. For example /home/yourname/opt/qcad...
Ironfighter
Post by Ironfighter » Mon Jun 28, 2021 8:16 am
I had actually followed the steps in the link you provided Andrew but I found the solution to my failure to run the installer by looking at the details of the file on my old laptop. My new MX Linux laptop wanted to "open with" XFCE terminal. My old laptop opens the file with Terminal Emulator. I just change the "open with" box selection to Terminal Emulator and it installed the file into my home/user/opt directory without any problems
Thanks for you help.
