Linux 64bit install : why Qt & not QT ? Which differences ?
Giuliano69
Post by Giuliano69 » Wed Mar 03, 2021 7:40 pm
I bought a Pro license of Qcad
Now I should upgrade to 3.26, and noticed that we have "two" versions of Qcad 3.26 Linux 64 bit, namely:
  • QCAD Professional 3.26.0 for Linux 64bit (Installer)
    QCAD Professional 3.26.0 for Linux Qt 5.14 64bit (Installer)
It seems to me, that neither the manual nor the email reply order, explain WHICH DIFFERENCES exist between this two versions.
For what I can test, I can install both on Ubuntu 20.04.02.
BUT,
Are there any FEATURES, or GUI improvements in one of said versions ?
What will I benefit from installing one or the other ?
BR
Giuliano
PS
Maybe this info should be kept in the order confirmation email for next purchase users.
Re: Linux 64bit install : why Qt & not QT ? Which differences ?
Post by andrew » Wed Mar 03, 2021 9:03 pm
Try the most generic "QCAD Professional 3.26.0 for Linux 64bit (Installer)" package first.
If that does not work and you are using a modern Linux distribution running Wayland instead of X11, try the "QCAD Professional 3.26.0 for Linux Qt 5.14 64bit (Installer)". For older systems, the legacy packages might be the only ones that work ("QCAD Professional 3.26.0 for Linux Legacy Qt4 64bit (Installer)").
There is no difference in features, etc. However, Linux is extremely diverse and it's impossible to create a package that runs on all Linux systems. It's also very hard to predict which package will work on your system.
If one works and the other one doesn't then that would be the benefit of the one that works. If both work, there's no difference.
Giuliano69
Post by Giuliano69 » Mon Mar 08, 2021 9:09 am
Hi Andrew,
thanks for your kind reply.
I tested BOTH on ubuntu 20.04.02
Both works.
Giuliano
berke
Post by berke » Wed Jul 20, 2022 1:09 pm
For what it's worth, qcad-3.27.6-pro-linux-qt5.14-x86_64 doesn't work on Debian 11 under Sway (Wayland) - the program doesn't open a window. When I start it, it prints this and then nothing further happens:
QCAD version  3.27.6
enable high dpi scaling
14:05:13: Debug:    loading plugins...
14:05:13: Debug:    loading static plugins...
14:05:13: Debug:    trying to load theme stylesheet:  themes/Dark/stylesheet.css
14:05:13: Debug:    trying to load theme stylesheet:  themes/Dark/stylesheet_linux.css
Warning:  Failed to load client buffer integration: "wayland-egl"
Warning:  Available client buffer integrations: ()
Warning:  No shell integration named "xdg-shell" found
Warning:  No shell integration named "xdg-shell-v6" found
Warning:  No shell integration named "wl-shell" found
Warning:  No shell integration named "ivi-shell" found
Warning:  Loading shell integration failed.
Warning:  Attempted to load the following shells ("xdg-shell", "xdg-shell-v6", "wl-shell", "ivi-shell")
14:05:14: Debug:    CadToolBar.initStyle
14:05:14: Debug:    EcmaScriptShell.initStyle:
14:05:14: Debug:    loading plugins...
14:05:14: Debug:    loading static plugins...
14:05:15: Debug:    loading plugins...
14:05:15: Debug:    loading static plugins...
Warning:  Wayland does not support QWindow::requestActivate()
If I use qcad-3.27.6-pro-linux-x86_64 then it works fine. The previous version 3.27.1 works fine as well but I upgraded to see if some drawing order glitches involving background images were fixed.
