Sorry I new to this portal and QCAD
First installing QCAD professional and I am getting an error message that I must install it on a local drive. I am using window 10 64bit and installing on c:.
Please help me.
Direct me to we’re I can get help.
Help with installation
- Capture installation error'.PNG (42.29 KiB) Viewed 7518 times
Re: Help with installation
hi,
could you move the smallest message box so we can read the folder name?
I really hope that I never have to encounter that!
This is an error from the Windows Installer (the software that installed MSI files) and unrelated to QCAD.
It seems to be a common problem on Windows and there are several approaches to fix it:
https://www.google.com/search?q=msi+ins ... hard+drive
For example:
https://superuser.com/questions/1069513 ... tall-error
Or:
https://www.thefreewindows.com/19928/fi ... ard-drive/
Alternatively, you can simply download the .zip archive from us instead. This can be extracted and run from anywhere on any disk.
PS: Moved topic to "QCAD Installation and Upgrades" forum.
For example:
Or:
