[solved] QCAD win32 is not running in Windows XP
zelea202
Post by zelea202 » Thu Aug 27, 2020 12:17 am
I don't suppose anyone cares but the win32 version is not running on Windows XP anymore (it says not a valid win32 application).
I have an VESA monitor back-mounted little computer controlling my CNC router which is running XP.
Re: QCAD win32 is not running in Windows XP
Post by Husky » Thu Aug 27, 2020 4:38 am
... version is not running on Windows XP anymore (it says not a valid win32 application).
Yes, I can confirm that.
@Andrew
Version qcad-3.24.3.10-pro-win32 (Archive) runs flawless on XP ...
I don't suppose anyone cares but the win32 version is not running on Windows XP anymore ...
Honestly, I tested it with a smirk on my face but that should remain our secret, ok? :wink:
Post by andrew » Thu Aug 27, 2020 7:36 am
It was becoming more and more of a compromise to support the whole stretch of Windows systems from XP to 10 with one single binary. Therefore, we've decided to create a separate "legacy" binary for Windows XP. You can find it in your download section under
QCAD Professional 3.25.0 for Windows XP 32bit (Installer)
This is just the good old binary, we've used before which might or might not also work on newer Windows installations.
gdhy
Re: [solved] QCAD win32 is not running in Windows XP
Post by gdhy » Thu Sep 09, 2021 4:30 pm
bonjour
could you give me a link
DACQ Professional 3.25.0 pour Windows XP 32 bits (Installer)
thanks
Post by andrew » Thu Sep 09, 2021 4:33 pm
gdhy: Please use your personal download link and click on "QCAD Professional 3.26.4 for Windows" then "QCAD Professional 3.26.4 for Windows XP 32bit (Installer)".
Accessing your downloads:
https://www.qcad.org/accessing-downloads-updates
gdhy
Post by gdhy » Thu Sep 09, 2021 6:11 pm
merci
je vais essayer cela et vous tiendrai informé
gdhy
Post by gdhy » Fri Sep 10, 2021 8:25 am
tout est OK merci
