Set install folder for quiet install with QCAD Pro
weze
Post by weze » Mon Jun 15, 2020 9:09 pm
Is there a possibility to set the install folder via command line when starting the installer?
We are using QCAD Pro 3.24.3 win64 installer 'qcad-3.24.3-pro-win64-installer.msi'. We are planning to distribute QCAD Pro as an integrated CAD app with our software product and would prefer quiet install of 3rd party apps. We use QtIFW to create installer packages.
Thanks for any hints!
Re: Set install folder for quiet install with QCAD Pro
Post by andrew » Mon Jun 15, 2020 9:23 pm
msiexec /i qcad-3.24.3-pro-win64-installer.msi INSTALLDIR="C:\myfolder" /qn
Note that this is a Microsoft Installer question, not directly related to QCAD. See also:
https://stackoverflow.com/questions/883 ... -directory
Is there a need for it to be "installed" (i.e. link DXF files and DWG files to QCAD)? Otherwise, I'd recommend to simply unpack the ZIP file we also offer. That's just unzip and run (qcad.exe), no further installation required. DXF/DWG files will not be linked with QCAD.
weze
Post by weze » Mon Jun 15, 2020 9:42 pm
Thank you for your immediate response!
No there's no need to link DXF/DWG with QCAD, I simply didn't recognize the ZIP option.
