Change from free version to professional
DanB
Post by DanB » Fri May 22, 2020 10:29 pm
I have been using the free version for several months and would like to go to the professional version. What is the procedure?
Re: Change from free version to professional
Post by Husky » Sat May 23, 2020 12:00 am
That is pretty straight forward .. :wink:
You can order your copy within the QCAD Shop ...
https://www.qcad.org/en/online-shop?cur=USD
... and just follow the instructions. Basically you get a download link - download and install the version regarding to your OS. Maybe a good idea to uninstall the free version first or at least make sure that the Pro version isn't installed in the same directory like the free version.
