QCadCam Fails to load
mlwoy
Post by mlwoy » Wed May 15, 2019 5:06 pm
Am experiencing a problem trying to load Qcadcam in the windows 32 bit version. When I launch it it fails at 69%. A recent posting said to remove the Qcad installation directory, where do I find that.
Qcad is also loaded and it works fine, it is only the CAM part that looks like it is failing.
Version.3.21
Windows 7 32 bit vesion
Re: QCadCam Fails to load
Post by andrew » Wed May 15, 2019 5:24 pm
Note that this could also be a problem with OpenGL support on your system. To check if that is the problem, please move the file C:\Program Files\QCADCAM\plugins\qcadgles3d.dll to your Desktop and try to start QCAD/CAM again. QCAD/CAM sill then start without OpenGL support (no 3D preview).
