[solved] QCAD 3.19 failed to launch, WIN 7 32-bit
mimatech
Post by mimatech » Thu Dec 07, 2017 9:48 am
I was using QCAD 3.4.5 for a long time now and I decided to upgrade to 3.19 today.
Installation completed without problem.
When I would like to start QCAD, the splash screen is displayed, adds-on (or modules i dond't know) are loaded then the splash screen disappear and nothing more....
Nothing is stuck in the task manager, no trace of QCAD.
I removed and reinstalled QCAD with the same behavior.
Any hint to know what is going on ? Thank you.
Re: QCAD 3.19 failed to launch, WIN 7 32-bit
Post by andrew » Thu Dec 07, 2017 10:03 am
Please uninstall and completely remove QCAD (make sure that the directory C:\Program Files\QCAD is deleted).
Then re-install QCAD again.
mimatech
Post by mimatech » Fri Dec 08, 2017 8:19 am
Deleting entirely c:\program files\QCAD and fresh install of 3.19.1 resolved the problem !
Thank you !
