QCAD on Ubuntu 22.04.1 crashes
asala
Post by asala » Tue Oct 24, 2023 10:01 pm
PC with 6.2.0-34-generic #34~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep 7 13:12:03 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
First I installed QCAD trial version: all right, no issues.
Then I purchased the PRO version, downloaded qcad-3.28.2-pro-linux-x86_64.run, made it executable and run from a terminal window. Apparently the installation was OK. No errors
But starting it I get the splash screen, then nothing. Running ./qcad from terminal window I get
~/opt/qcad-3.28.2-pro-linux-x86_64$ ./qcad
QCAD version 3.28.2
22:57:57: Debug: loading plugins...
22:57:57: Debug: RDwgPlugin::init
22:57:57: Debug: RProScriptsPlugin::init
22:57:57: Debug: RTracePlugin::init
22:57:57: Debug: loading static plugins...
22:57:57: Debug: trying to load theme stylesheet: themes/Default/stylesheet.css
22:57:57: Debug: trying to load theme stylesheet: themes/Default/stylesheet_linux.css
22:57:58: Debug: loading plugins...
22:57:58: Debug: loading static plugins...
22:57:58: Debug: checking for QCAD Pro updates...
Warning: QSslSocket: cannot resolve CRYPTO_num_locks
Warning: QSslSocket: cannot resolve CRYPTO_set_id_callback
Warning: QSslSocket: cannot resolve CRYPTO_set_locking_callback
Warning: QSslSocket: cannot resolve ERR_free_strings
Warning: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup
Warning: QSslSocket: cannot resolve EVP_CIPHER_CTX_init
Warning: QSslSocket: cannot resolve sk_new_null
Warning: QSslSocket: cannot resolve sk_push
Warning: QSslSocket: cannot resolve sk_free
Warning: QSslSocket: cannot resolve sk_num
Warning: QSslSocket: cannot resolve sk_pop_free
Warning: QSslSocket: cannot resolve sk_value
Warning: QSslSocket: cannot resolve SSL_get_peer_certificate
Warning: QSslSocket: cannot resolve SSL_library_init
Warning: QSslSocket: cannot resolve SSL_load_error_strings
Warning: QSslSocket: cannot resolve SSL_get_ex_new_index
Warning: QSslSocket: cannot resolve SSLv2_client_method
Warning: QSslSocket: cannot resolve SSLv3_client_method
Warning: QSslSocket: cannot resolve SSLv23_client_method
Warning: QSslSocket: cannot resolve SSLv2_server_method
Warning: QSslSocket: cannot resolve SSLv3_server_method
Warning: QSslSocket: cannot resolve SSLv23_server_method
Warning: QSslSocket: cannot resolve X509_STORE_CTX_get_chain
Warning: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf
Warning: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf
Warning: QSslSocket: cannot resolve SSLeay
Warning: QSslSocket: cannot resolve SSLeay_version
Warning: QSslSocket: cannot call unresolved function CRYPTO_num_locks
Warning: QSslSocket: cannot call unresolved function CRYPTO_set_id_callback
Warning: QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback
Warning: QSslSocket: cannot call unresolved function SSL_library_init
Warning: QSslSocket: cannot call unresolved function SSLv23_client_method
Warning: QSslSocket: cannot call unresolved function sk_num
./qcad: line 13: 115534 Segmentation fault (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=0 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
Please use the offscreen or minimal platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
BTW, the trial version keeps working correctly
What should I do ?
Thank you and best regards
Re: QCAD on Ubuntu 22.04.1 crashes
Post by CVH » Wed Oct 25, 2023 6:29 am
Similar crash report with solution here:
https://www.qcad.org/rsforum/viewtopic.php?f=34&t=9490
I would remove the trial version first. :wink:
Post by andrew » Wed Oct 25, 2023 7:08 am
Please try the installer "qcad-3.28.2-pro-linux-qt5.14-x86_64.run" instead (labeled "QCAD Professional 3.28.2 for Linux Qt 5.14 64bit (Installer)" on your download page).
asala
Post by asala » Wed Oct 25, 2023 7:35 am
This version seems OK. Let me check it thoroughly
Thank you for your support
asala
Post by asala » Wed Oct 25, 2023 7:53 am
Yes, it seems the same problem with the same solution, and it works. Thank you
BTW I uninstalled the trial version but... things don't change. The solution is to use qt5 version.
Best regards
