Hey all,
Just bought Qcad professional. Lots to do!
Which version of MacOS M1 should I install. I have a MacBook Air M1. I will upgrade in the fall to M2 (or whatever they are selling).
Do I want/need Qt6? I don't know what it us.
Thanks for the input!
FB
Which MacOS M1 verision to install
- Full Member
- Screenshot 2023-07-28 at 9.38.40 AM.png (298.95 KiB) Viewed 33214 times
- Full Member
Re: Which MacOS M1 verision to install
I'm running the latest MacOS. Ventura 13.5.
Yes, I would recommend installing the Qt 6 package as it fixes some problems on M1/M2 CPUs.
If you have a multi-screen setup you might experience crashes when disconnecting / reconnecting screens. If you absolutely need do that a lot, better install the Qt 5 package.
- Full Member
No multi-screen At least no yet. So Qt6 it is. Thanks.
How do I check for ongoing updates? Is there auto-update notification?
You could subscribe to this forum: https://www.qcad.org/rsforum/viewforum.php?f=16franksbedford wrote: ↑Fri Jul 28, 2023 9:52 amHow do I check for ongoing updates? Is there auto-update notification?
(Whole the way at the bottom left )
