QCAD on Pinebook Pro (aarch64)
tomek
Post by tomek » Sun Feb 07, 2021 11:24 pm
I refer to the forum asking how to install qcad pro on pinebook pro (aarch64).
There are only community editions in the distribution (tested on Manjaro and Fedora), but as a subscriber I would like the full version.
In the subscriber directory, I tried to install * for Linux 64 (installer), which installed but didn't run.
Thank you for answer.
Tomek.
QCADpro 3.26.4.7 / Win10pro 64 bit and FedoraWorkstation_32 64 bit
Re: QCAD on Pinebook Pro (aarch64)
Post by andrew » Mon Feb 08, 2021 9:41 am
Hello, this is an ARM architecture CPU. Unfortunately, we do not offer binaries for this platform (all Linux packages are for Intel processors). The OpenDesign libraries (used among other things for DXF and DWG support and spline from fit points) is not available for Linux on ARM.
tomek
Post by tomek » Mon Feb 08, 2021 8:31 pm
So I understand that there is no official support for ARM and that community editions in Linux distributions for ARM processors are unofficial work, and therefore only these versions can be used.
Tomek.
QCAD on ARM
Post by andrew » Tue Feb 09, 2021 10:46 am
Yes. Third party QCAD Community Edition packages are based on sources at:
https://github.com/qcad/qcad
These are not from us but compiled and distributed under the QCAD open source license.
