Does Qcad pro save hatches' alpha values in dxf?
bob93
Post by bob93 » Sun Jan 29, 2023 12:02 am
Hello. I have qcad community 3.27.1 on linux
I use semitransparent solid hatches a lot and one problem is that hatches' alpha values don't save, so every time I open the file they're back at 255 and I have to change them manually for every hatch. It gets time consuming.
I thought perhaps this is simply a qcad community version limitation and I should upgrade, so I went to the Qcad pro features page but I didn't see any mention of this anywhere.
Is this still a problem in Qcad pro?
Re: Does Qcad pro save hatches' alpha values in dxf?
Post by Husky » Sun Jan 29, 2023 12:59 am
Hello bob93 - welcome to the QCAD forum.
Indeed - I can confirm that. Thanks for the report!
No - that is not a QCAD CE limitation. The same issue can be find in Pro what I consider as a bug.
However - it is always a good idea to go Pro ... :lol:
I'll file a bugreport for you.
Bugreport:
https://www.qcad.org/bugtracker/index.p ... sk_id=2449
Post by andrew » Sun Jan 29, 2023 1:12 pm
I can confirm this limitation of the QCAD Community Edition, respectively the DXF version that is used by QCAD CE.
However, I cannot reproduce this with QCAD Professional 3.27.9.
Here's how I proceed:
- Create a solid filled hatch
- Select the hatch entity
- Change property Alpha to 100
- Reload the file
Husky: Please note that DXF R15 and older do not support transparency in hatch entities. Could it be that you are using an older format version?
Post by Husky » Sun Jan 29, 2023 9:59 pm
Yes - I tricked my self with a logical fallacy. I used for testing the with CE created file in Pro what means it was a R15 format.
Sorry for my misleading statement - and yes, you are right: Pro is capable to save alpha values! :oops: :oops: :oops:
