my screen ends with the command line. using pc laptop running win 11
attached pdgf screen shot
thanks'
don
status bar not showing
- qcad screen.pdf
- (156.44 KiB) Downloaded 161 times
Re: status bar not showing
You can display the status bar using the menu:
View > Status Bar
View > Status Bar
soooo simple! thank you!
don
don
I would like to refer to:
https://www.qcad.org/rsforum/viewtopic.php?f=33&t=9525
And the mentioned Bugreport dated 11.07.2016.
It is somewhat different than the widgets that are listed in the Widget list.
For one, one can not detach or pick & place the Status Bar.
But I think it is just the matter of including RGuiAction.setChecked().
