when going from an old AutoCAD to QCAD, I get objects not part of the drawing
georgegraz
Post by georgegraz » Wed Nov 23, 2022 2:18 pm
See the part of a drawing attachment. Also, in trying to fix this, I can't right to left the mouse to select any objects in the window.
George
Windows 10
QCAD
Version: 3.27.8.0 (3.27.8)
4673-037 when opening in QCAD - These objects show up .dwg
(44.95 KiB) Downloaded 189 times
QCAD issue.pdf
(23.05 KiB) Downloaded 183 times
J-J
Moderator
Re: when going from an old AutoCAD to QCAD, I get objects not part of the drawing
Post by J-J » Wed Nov 23, 2022 6:49 pm
Your drawing has Z coordinate which QCAD cannot handle. Flatten your drawing with Misc menu
flatten dwg.jpg (124.95 KiB) Viewed 3408 times
JJ Win7 pro-64
georgegraz
Post by georgegraz » Wed Nov 23, 2022 11:50 pm
J-J, Thanks for the reply. I tried just selecting the flatten command, didn't do anything. I tried selecting the area, then selecting the flatten command. Not sure how to use the command. Google doesn't help.
George
Post by Husky » Thu Nov 24, 2022 12:09 am
J-J workaround works flawless! Flatten a 3D drawing will set all Z values to 0. That is not what you can see on first sight in Model_Space but it will make the drawing processable in a 2D application like QCAD.
No selection required! Just launch below Menu/Misc/Modify the tool "Flatten drawing to 2D" and it is imminently executed.
Try this again after you used the flatten tool ... :wink:
georgegraz
Post by georgegraz » Thu Nov 24, 2022 12:59 am
It doesn't appear to do anything. The black objects are still there. Is there somewhere that tells you it has 3D objects? On the complete drawing, that is the only place it has that.
Post by Husky » Thu Nov 24, 2022 1:36 am
Sorry, not sure what you mean with that. Please provide a screenshot on this "black objects".
A selected entities will show in the QCAD Property Editor z-values >0. Note: Z values are not shown by default - you have to activate it in Application Preferences ...
... and this is what you will see in a 3D program.
georgegraz
Solved - Re: when going from an old AutoCAD to QCAD, I get objects not part of the drawing
Post by georgegraz » Thu Nov 24, 2022 2:04 am
Husky & ,J-J,
Thanks very much. Enabled seeing the Z now. I also can select part of an object going from left to right. Have a great day.
George
Re: Solved - Re: when going from an old AutoCAD to QCAD, I get objects not part of the drawing
Post by Husky » Thu Nov 24, 2022 2:25 am
Great!
Have a great day.
You too. :wink:
Post by CVH » Sat Nov 26, 2022 9:14 am
May I remark that there are 220 Face Entities in your drawing.
Some are face on and some are not.
What we see as lines can be a Face entity on its side.
Flatten to 2D the contour re-traces the displayed line twice.
Faces explode to the outer contour as closed Polylines.
One can not create Face entities in QCAD but it supports them.
