Problem with Arc Length Dimension
John Hyslop
Post by John Hyslop » Tue Nov 22, 2022 11:36 pm
Hi Andrew
There seems to be a problem with the "Arc Length" dimension?
It's scaled by 100? dxf attached for your reference..
WhatsGoingOnHere.dxf
(147.87 KiB) Downloaded 192 times
Cheers
John
OS: Linux Mint 20.3 x86_64
Qcad/Cam Version: 3.27.8.0 [3.27.8]
Build Date: Oct 6 2022
Revision: dea3962
Qt Version: 5.14.2
Architecture: x86_64
Compiler: gcc 5.4.0
Re: Problem with Arc Length Dimension
Post by Husky » Wed Nov 23, 2022 12:04 am
Hi John,
confirmed as a bug. Looks like it is broken since Version: 3.26.4.0
Please file a bug - report below:
Thanks for the hint! :wink:
John Hyslop
Post by John Hyslop » Wed Nov 23, 2022 12:19 am
Hi Husky
Thanks for the confirmation.. Bug reported..
https://www.qcad.org/bugtracker/index.p ... sk_id=2425
Cheers
John
Post by CVH » Wed Nov 23, 2022 5:41 am
Hi John,
In your file the linear measurement factor defaults to 100.
I can't replicate that in a new file.
Probably all since DimStyle overrides where implemented.
So, in essence the displayed value is correct, the scale not and not intended.
The odd thing is that there is no scale option in the Option Toolbar for the DimArcLEngth.js script.
Temporary fix: Set the linear measurement factor to 1. :wink:
Post by CVH » Wed Nov 23, 2022 6:37 am
On top,
Remove Styles Overides (DX) doesn't change anything although Drawing Preferences dimension Size scale factor is 1 ... :?
Post by CVH » Wed Nov 23, 2022 8:01 am
All works perfectly as expected in a new file or in files I have stored over here, in any unit, in recent dxf file versions.
All but when I do the same in John's file or copy/paste to that file.
I start to wonder what 'Overrides Styles' is all about ...
I would presume that removing them would revert to the Drawing Dimension Preferences ... :shock:
