[solved] ATTDEF text height and angle changed when save a DXF file if text start not same with alignment
toob
Post by toob » Fri Nov 04, 2022 6:05 am
Bug:
- Current behaviour: ATTDEF text height and angle changed when you open and save a DXF file when text start(10,20,30) is different from alignment point(11,21,31)
- Expected behaviour: ATTDEF text height and angle should not change when saved
OS/QCAD Version:
- macOS 11.7
- QCAD Pro 3.25.2.0 (3.25.2)
To replicate:
- open and save the attached DXF file.
attdef-text-height-and-angle-bug-when-save.dxf
(1.02 KiB) Downloaded 268 times
- and re-open again in QCAD
Note:
- I cannot submit an issue in the bugtracker. https://www.ribbonsoft.com/bugtracker/
- I searched the forum and bugtracker tasks. I found no related topic.
Re: ATTDEF text height and angle changed when save a DXF file if text start not same with alignment
Post by CVH » Fri Nov 04, 2022 6:47 am
ATTDEF text height and angle changed when you open and save a DXF file ...
I can confirm this on Win7 32 bit with QCAD 3.27.6.0
The issue it is not depending on file format what was R11/R12.
There you first have to create a separate account. :wink:
Post by Husky » Fri Nov 04, 2022 6:54 am
the prompt text in the attribute definition is missing. Please complete the dialog and try again to save/load the drawing.
Post by CVH » Fri Nov 04, 2022 7:32 am
Perhaps malpractice but probably still a bug, the prompt text was a single space.
IMHO this should not affect angle and size.
With a prompt starting with a space the file is saved/opened correctly.
toob
Post by toob » Fri Nov 04, 2022 9:50 am
Hello @Husky,
The prompt text was a whitespace from other software. Changing that MAY have an unexpected result on the said software.
Which workaround do you suggest? that would be the least invasive
- [ ] add placeholder prompt text for all missing entities: prompt text = ` a` (whitespace and a) as you mentioned
- [ ] edit text start point(10,20,30) to match alignment point(11,21,31)
- [ ] contact the said software support
toob
Post by toob » Fri Nov 04, 2022 9:56 am
Note: I've tested both workaround. They DO work.
Post by Husky » Fri Nov 04, 2022 6:49 pm
Hi toob,
I never told you to use white spaces as a prefix! I would suggest to use solution one without the prefix white space. BTW - it is not a workaround! If a QCAD tool is used as intended it will work.
toob
Post by toob » Mon Nov 07, 2022 2:51 pm
@Husky Thanks
  • I'll use the prompt as you've suggested
SHOULD I put a [solved] in front of the topic's subject? It seems like other members MAY think that this is a bug.
Post by CVH » Mon Nov 07, 2022 7:00 pm
It seems to be a bug, please file a bug report, include file and a link to this topic.
Post by Husky » Mon Nov 07, 2022 8:43 pm
Yes - I'll do it for you. :wink:
toob
Re: [solved] ATTDEF text height and angle changed when save a DXF file if text start not same with alignment
Post by toob » Fri Nov 11, 2022 10:28 am
@Husky
Note: setting prompt will NOT solve the issue in QCAD scripting environment.
  • feel free to ping me to create a new topic for this
To replicate:
  • Change the 2 input vars at the top of the script
  • Run the script with QCAD: in QCAD GUI or using the QCAD Command line tool CLI
Note: the related code regions
          if (en.getPrompt() === ' ') {
            en.setPrompt('a'); // does NOT work (pic1)
            // en.setPosition(en.getAlignmentPoint()); // does work (pic2)
Screenshots:
Screen Shot 2022-11-11 at 4.31.43 pm.png (46.79 KiB) Viewed 6389 times
Screen Shot 2022-11-11 at 4.32.01 pm.png (36 KiB) Viewed 6389 times
Post by Husky » Fri Nov 11, 2022 8:03 pm
@Husky
For the record - I never said a script will fix the issue! Define Block Attributes as intended and it will work like a charm. :wink:
