Win 10 Pro
QCAD Pro 3.27.1.0 and 3.27.8
It appears that the command line prompt of "Specify point for Y coordinate" does not clear after placing an object using the X/Y From Point snap option. Additionally, when using the Y/X From Point option, the same Y prompt will re-appear after placing the X coordinate.
See
This seems to occur when using several of the line tools and the rectangle with size tool, but not with tools such as rectangle (RE) or Circle, Point (CI).
I would have just entered in the bugtracker but I wanted to make sure I wasn't crazy first.
Possible Bug: CL Prompt with X/Y From Points [solved]
- ryancousins
- Premier Member
