Text in Block outside Viewport area is displayed
Post by CVH » Sat Oct 29, 2022 6:51 am
Same example drawing from here:
https://www.qcad.org/rsforum/viewtopic. ... 972#p38972
An identical Viewport area is added to the Layout Block, what is common practice.
Open file and switch to Layout.
Toggle the visibility of the 'zz_Viewports' Layer.
Tested/created with QCAD Pro 3.27.6.0 Win7 32bit msi installer.
PS: The behavior of the file is exactly the same under 3.27.8 :wink:
