Printing
KHE
Printing
Post by KHE » Wed Oct 05, 2022 10:33 pm
OS:
Edition Windows 11 Home
Version 21H2
Installed on ‎2021-‎12-‎06
OS build 22000.978
Experience Windows Feature Experience Pack 1000.22000.978.0
QCAD PRO
Version: 3.27.7.0 (3.27.7)
Internet: QCAD.org
Build Date: Sep 29 2022
Revision: 58ecdde
Qt Version: 5.13.2
Architecture: x86_64
Compiler: MSVC++ 14.0 (2015)
I am having trouble with printing. Simple I have a 3" x 3" part. Print at 1:1. Nothing happens in the current version.
Re: Printing
Post by Husky » Wed Oct 05, 2022 11:38 pm
Can't reproduce that issue. Please elaborator what "having trouble" and "nothing happens" exactly means. If possible please attach the dxf/dwg file or even screenshots for us. Thanks.
John Hyslop
Re: Printing
Post by John Hyslop » Thu Oct 06, 2022 12:20 am
Hi All
I'm having trouble scaling down any job I want to print or save as PDF the paper settings don't seem to be working.... it works fine on previous version
but not on 3.27.7 .... Linux Version
qcadcam-3.27.7-pro-linux-qt5.14-x86_64
Linux Mint 20.3 64bit
Cheers
John
PS Added some screenshots, to simulate this just draw a 2974x1695 rectangle.. and scale to 0.1 on A3
Re: Printing
Post by Husky » Thu Oct 06, 2022 12:49 am
Hi John,
I've problems to reproduce that on Windows10. Could you post the dxf/dwg? PM is ok too ... :wink:
Re: Printing
Post by Husky » Thu Oct 06, 2022 1:12 am
Ok, got it on Windows10 too.
pdf output:
Please file a bugreport below ...
... but you already know the drill. :lol: :lol: :lol:
John Hyslop
Re: Printing
Post by John Hyslop » Thu Oct 06, 2022 1:19 am
Thanks Husky.. I'm doing it shortly :lol:
Cheers
John
John Hyslop
Re: Printing
Post by John Hyslop » Thu Oct 06, 2022 1:25 am
KHE
Re: Printing
Post by KHE » Thu Oct 06, 2022 4:15 am
2022-10-05 23_06_56-Drawer guide.dxf _ - QCAD.png (95.27 KiB) Viewed 4157 times
In the pic you will see a simple part that is scaled 1:1 ready to print. When I press the print icon the printer dialog pops up. This afternoon Qcad would bring up (not responding) and not print. Eventually it would return the same screen. Now 11:14 pm I just successfully printed the same file. Strange I am not sure what happened earlier today. I will repost if the problem occurs again.
Re: Printing
Post by Husky » Thu Oct 06, 2022 4:53 am
Glad to hear it is working now. If it happens again please don't hesitate to post again.
