Filter
KHE
Filter
Post by KHE » Wed Oct 05, 2022 9:27 pm
OS:
Edition Windows 11 Home
Version 21H2
Installed on ‎2021-‎12-‎06
OS build 22000.978
Experience Windows Feature Experience Pack 1000.22000.978.0
QCAD PRO
Version: 3.27.7.0 (3.27.7)
Internet: QCAD.org
Build Date: Sep 29 2022
Revision: 58ecdde
Qt Version: 5.13.2
Architecture: x86_64
Compiler: MSVC++ 14.0 (2015)
I am having troubles with filter selection.
Using the filter intersect option no longer works.
Make selection of multiple entities. Entities are by colour not level.
Set: entity type to any
Set: property to colour
Set: comparison to +(is)
Set: value to red
Click intersect with current selection, all selections are removed, red should have been left behind
Re: Filter
Post by Husky » Wed Oct 05, 2022 10:06 pm
Yes, I can confirm that issue. Looks like the Selection Filter fails for multiple filter scenarios in the newest QCAD release.
I'll file a bugreport.
In the case you need the filter functionality right away please use a previous QCAD version like ≤ 3.27.6.0. Thanks.
Bugreport:
https://www.qcad.org/bugtracker/index.p ... sk_id=2402
KHE
Re: Filter
Post by KHE » Wed Oct 05, 2022 10:31 pm
Thank you. A dumb question, How do I go back to the last version easily?
Re: Filter
Post by Husky » Wed Oct 05, 2022 11:32 pm
Did you use the zip or the msi file for installation?
Did you as recommended secure the downloaded installation files to your Dropbox, your Google Drive, iCloud Drive, One Drive, etc.?
Do you still have a prior version on your system?
KHE
Re: Filter
Post by KHE » Thu Oct 06, 2022 4:21 am
I use the .msi files. I save all version to my drive. So yes I have every version I have purchased. I can initiate 3.27.6. Does that overwrite the current version so I can use the last version? I use these filter for my cam work. It saves me alot of time. Not having that feature is not desirable.
Re: Filter
Post by Husky » Thu Oct 06, 2022 4:48 am
Great!
Yes, execute the 3.27.6 msi which will remove the 3.27.7 and installs instead the 3.27.6. Please keep us posted.
