Labels in blocks not rendered properly
manelclos
Post by manelclos » Tue Sep 20, 2022 1:38 pm
Hi, I need the blocks to render properly as we have many in a map file.
Using blocks:
Screenshot 2022-09-20 at 14.36.03.png (93.11 KiB) Viewed 3029 times
Blocks exploded:
Screenshot 2022-09-20 at 14.36.55.png (72.26 KiB) Viewed 3029 times
Is there anything I can do to use the original file? Exploding the blocks is not perfect as some items are misplaced.
Thanks!
Re: Labels in blocks not rendered properly
Post by andrew » Tue Sep 20, 2022 1:40 pm
Please attach your file, so we can help efficiently. See also forum rules in red at the top. Thanks.
manelclos
Post by manelclos » Tue Sep 20, 2022 2:01 pm
Hi, sorry, QCad version is 3.27.6.0 (3.27.6) on Mac OS Big Sur.
Will send the files in private.
Thanks!
Post by andrew » Tue Sep 20, 2022 2:40 pm
The two files do not use any blocks.
All dimensions seem to have a size factor override of 10.
You might want to try:
- Select > Select All
- Dimension > Remove Style Overrides
manelclos
Post by manelclos » Fri Sep 23, 2022 1:38 pm
Hi Andrew, sorry for the last reply. Tested your suggestion today and it works like a charm. Thanks a lot!
